When I turned them on, they would not turn off and would stay in the fast position. I changed the motor to see if that was the problem, it happened again. I went back and changed the fuses and the switch in the column. It was working perfectly at every speed and even turned off. It worked for about two weeks and then it stopped returning to the stop position. In other others, it would stop half way when coming down. I would give it a little push and it would continue. I changed just about everything I could, the motor, fuses, blades, arbitrator arms, bushings everything. The problem is still occurring, I checked the voltage of the connector. When the key is on, two of the five terminals have voltage. I'm not sure if that is because the wiper are not on, I got frustrated and stop working on it.
Sep 10, 2019 at 11:03 AM
