Windshield wiper control system troubleshooting?
2000 OLDSMOBILE INTRIGUE
182,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
IND35TRUCTIBLE1
  • 7 POSTS
Wipers don't work, power at motor plug so replaced motor w/pulse module still won't work. could it be the switch and how to check it?
Oct 20, 2022 at 8:39 PM
If you have power to the motor, either the motor is bad or there is no ground supply to complete the circuit.
There should be a black wire in the harness at the motor. Disconnect the connector and check the black wire for continuity to ground.
I attached the wiper wiring schematic circuit below, so you have a reference. If there is power, the motor is good (new) it should run if there is a ground provided.
Let me know what you find.
See pics below.
Oct 20, 2022 at 9:12 PM
IND35TRUCTIBLE1
  • 7 POSTS
Thanks, I'm going to check the ground circuit out and see what I can find. Thought maybe switch but there's power to the motor wires. It's driving me nuts.
Oct 20, 2022 at 10:09 PM
No problem whatsoever. If you have power, this is the only thing that makes sense. If you can, let me know what you find. Also, you may want to run a new ground from the motor to the battery negative to see if that makes a difference.
Oct 21, 2022 at 8:25 PM
IND35TRUCTIBLE1
  • 7 POSTS
Thanks again, I was thinking the same thing. i plan on jumping on it in the morning while I'm off work so I'll let you know what happens.
Oct 21, 2022 at 11:20 PM
IND35TRUCTIBLE1
  • 7 POSTS
Well, it was the ground circuit. I traced down the ground distribution and cleaned up and redid every ground. The ground for the wipers was corroded and actually had a broken wire at the ground point under ABS unit. i also ran a new ground lead from the wiper motor body to a clean spot on the body. Turned them on and the linkage bind up and popped apart. The motor runs but the wipers don't move. I think I have the cam on top of wiper motor shaft out of position, but I'll try to address that tomorrow. Thanks a million. I'm glad I finally figured it out.
Oct 22, 2022 at 1:47 PM
Thanks for the update. I'm glad to know you got it working. The ground was the only thing left I could think of. LOL I'm glad that took care of it.
As far as the linkage/wiper transmission, I attached directions below for the installation of everything. I hope it helps.
Take care and let me know how things turn out for you.
See pics below.
Oct 22, 2022 at 10:29 PM
