Windshield washer pump not making noise and no fluid front or rear
2006 NISSAN PATHFINDER
200,000,000 MILES • 4 CYL • 4WD • AUTOMATIC
BABYROCKY1
help my windshield washer pump is not making noise and no fluid is coming out of the front or rear. What could be the problem and how do i fix it?
Dec 10, 2016 at 8:38 PM
MHPAUTOS
  • 31,937 POSTS
Sounds as if the pump has failed, check your owner's manual to see if there is a fuse for this pump, if it is okay, you will have to remove the washer bottle and check for power at the pump with the switch pushed to wash. if you have power then the pump will be faulty.
Dec 10, 2016 at 9:36 PM
