See diagram below for WWS system layout.
Please first check that the washer fuse 9, 10A, on the dash fuse board is still intact.
https://fuse-box.info/toyota/toyota-mr2-spyder-w30-1999-2007-fuses
How to check a fuse:
If the fuse is good next check that you have 12V, with ignition on, at pin 2 at the washer pump. This is the blue wire.
How to check for 12V using a test light or voltmeter:
and
If no 12V is present, then next check that the blue wire between fuse 9 and the washer pump is intact.
How to test a wire:
If 12V is present at pin 2 at the washer pump, next check that a ground is applied to pin 1 when the washer switch is activated. If no ground is activated when pulling the washer switch then next check the wire, blue/yellow, between the pump and washer switch.
Hope this helps.
Cheers, Boris
Aug 16, 2022 at 2:58 AM
