Windshield replacement compatibility?
1988 DODGE DAKOTA
999,999,999 MILES • 3.9L • V6 • 2WD • AUTOMATIC
E2BELLAMY
  • 5 POSTS
I have a slight crack in my windshield and after reviewing online as well as calling around looking for a possible quick fix I have come to the conclusion that I have to replace it. Which windshields would fit in the place of my own? I know any Dakota within the same generation would work, that's not the question. It's more so a question of what other Dodge trucks used the same or similar windshield.
Dec 28, 2023 at 9:42 AM
Here is the information I found on this problem. I would call auto dismantling yards, but I must tell you most of the time a windshield will get broken when being removed.
Same Generation Dakotas: As you've correctly noted, other Dodge Dakotas from the same generation (1987-1996) will have compatible windshields.
Dodge Full-Size Trucks: Sometimes, manufacturers use similar or the same windshield designs for their vehicles within a close size and class range. For Dodge trucks of that era, this could potentially include the Dodge Ram of similar years. However, this is not a guarantee, as even slight differences in body design can mean windshields are not interchangeable.
Let us know if you need anything else.
Dec 28, 2023 at 11:29 AM
