Windows not working properly
2006 HONDA ODYSSEY
160,000 MILES
The windows will not work at all. uses are good, the door control is good. what else could it be? with key in door lock and turned twice all the windows go down and up, so the motors are good. any thoughts on what it could be?
Apr 4, 2021 at 12:58 PM
Good afternoon,
I attached a wiring diagram of the windows for you. There is a relay that controls power to the windows. I would check the voltage at the relay to see if it is powering the fuses.
I also attached a picture of the location of the power window relay.
Apr 4, 2021 at 1:48 PM
All fuses are good. changed the relay. Windows still won't work.
Apr 5, 2021 at 12:47 PM
Okay, can you check for power to the relay with the key on?
Apr 5, 2021 at 1:08 PM
How should I do that?
Apr 5, 2021 at 1:33 PM
You need to remove the relay and use a voltmeter to test for power.
I attached the guides in a previous post for using a voltmeter and checking a relay.
Apr 5, 2021 at 1:55 PM
