Windows not rolling down
2001 BUICK LESABRE
205,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
TYLER ERB
I can hear a noise in the relay when I press the switch. Only drivers side door. When I bought the car a couple months back it did not have any windows that would roll down. First I tried new window regulators motors in the front two windows because the back to rolled down with just a jump. Well, after I got those in they didn't roll down still. Only the dome lights and lock worked on the driver side door. I lifted the driver's seat up and pull the carpet back and underneath the driver seat a wire is corroded. So I took the piece off clean up the wire and the dome lights popped on in the locks worked but only the driver's door window would roll down. I tried new switches on the other three doors and I tried new relays and nothing is working. Here to find out wires were cut only on front passenger windows. I only have wires and not sure how they go. There's a blue and tan on door and new regulator has blue and red.
Jan 6, 2020 at 9:58 AM
Good afternoon,
The first thing I would do is check the fuses listed in the diagrams for power on both sides to be sure power is available.
then I would remove the driver's door panel and verify the orange wires to the module have power with the key on. You may have bad modules in the doors.
Jan 6, 2020 at 10:10 AM
