There are three orange wires at the driver's door module. Check for twelve volts on all of them. If it is missing on terminal "A", check for a defective thirty amp "power window" circuit breaker in the fuse box cleverly hidden under the back seat. If it is missing on terminal "A8", check the "DMV MDL" ten amp fuse, also under the back seat. If both of those are okay, but you do not have twelve volts on terminal "A7", suspect that module. I am sorry that I do not have a drawing of the plugs.
Mar 5, 2017 at 6:19 PM
