It sounds like the driver door module has gone out which is common. Here is the location of the module and the instructions on how to change it out. If you get used unit it might plug and play.
DOOR CONTROL MODULE PROGRAMMING/RPO CONFIGURATION
When replacing door control modules for export vehicles, all replacement door modules must be reprogrammed in order to relearn the vehicle identification number (VIN). This does not include domestic vehicles. When replacing a driver door module (DDM) or front passenger door module (PDM) the proper vehicle option configurations must be entered for both domestic and export vehicles.
The following steps explain how to program replacement door control modules:
1. For domestic vehicles proceed to step number 6.
2. With the scan tool, navigate to the main menu for the door control module that has been replaced.
3. Select Special Functions.
4. Select Door Zone Module VIN Relearn.
5. Follow the on screen instructions in order to complete the relearn procedure.
IMPORTANT: If the module being replaced is a DDM or PDM, proceed to the following steps.
6. Navigate to the main menu for the door control module being replaced.
7. Select Special Functions.
8. Select Set Options.
9. Select Vehicle Type.
10. Follow the on screen instructions in order to complete the set options procedure.
After performing the above steps the power windows must be initialized. Refer to Window Motor Programming - Express Function .
Below are the driver door module location and how to remove the door panel. Check out the diagrams (below). Please let us know what happens.
Jan 3, 2019 at 10:42 AM
