Windows not working properly
1997 MERCEDES BENZ E320
169 MILES • 2.3L • 6 CYL • 2WD • AUTOMATIC
JANET21JIM23
Windows do not work if I use the key in the passenger door. Back windows work up down.
Nov 27, 2018 at 5:01 PM
There are two fuses #1 and #2 in the rear fuse panel that need to be checked. Here are the window wiring diagrams so you can see how the system works and a guide to help you check for power at the fuse:
Nov 29, 2018 at 11:24 AM
