Windows will not roll up with any switch?
2008 DODGE AVENGER
120,000 MILES • 4 CYL • AUTOMATIC
SHAYLON
Both passenger windows will roll down with their own switch as well as the master switch but they won't roll up with any switch
Front passenger motor has been replaced but same issue
Mar 29, 2016 at 5:26 PM
CARADIODOC
  • 34,306 POSTS
This isn't a motor issue. If it runs one way, it will run the other way unless the cable has become shredded or tangled. The clue is if you watch the interior lights at night with the engine off, they will dim very slightly if the motor is trying to run. That would indicate you don't have a switch or wiring problem. You have a regulator / cable / pulley problem.
You must be aware that either the door switch or the driver's master switch can be at fault, even when one switch works and one doesn't. There are actually four switch contacts in every switch, and two are in use when any ONE switch is activated. That means the released switch can prevent the pressed switch from working.
Without digging out a wiring diagram to get wire colors, replacing the driver's switch is the fastest way to tell if that is the cause of the problem, provided you can find a used switch in a salvage yard. If you are going to have to buy a switch from the dealer, then we'll want to do some tests first to prevent wasting money on unneeded parts.
I'm recommending the driver's switch only because you have two failed circuits and they both have the driver's switch in common. You could also have two bad passenger switches.
Mar 29, 2016 at 7:56 PM
SHAYLON
Update:
Drivers window quit rolling up for about 10 minutes then worked again
Apr 4, 2016 at 12:00 PM
SHAYLON
Back passenger started working as well
Apr 4, 2016 at 12:41 PM
Yep, it sounds like the master switch is bad, this can cause a windows to sometimes work and then not, the clue is the problem effects more than one window which all lead through the master switch.
Apr 4, 2016 at 2:16 PM
TEXACA
  • 34 POSTS
is there another category or troubleshooting guide that will address on how to troubleshoot this problem for a 2014 Dodge Avenger? thanks
And are there schematics?
Oct 13, 2023 at 11:35 PM
TEXACA
  • 34 POSTS
... is there another category or troubleshooting guide that will address on how to troubleshoot this problem for a 2014 Dodge Avenger, thanks
And are there schematics.
Oct 13, 2023 at 11:36 PM
This post is for a 2008, please post your new question here, you must be logged in.
Oct 14, 2023 at 11:10 AM
