Well the driver door control module controls each of these items but they are all separate. Unless something happened to short this out it just doesn't seem to add up with what was done for it to all happen as once.
If you look at the wiring diagram it shows that the windows and switches for each side have separate fuses to each door module.
Let's just focus on one issue and fix that and see if the others get fixed as well.
Go to the DDM and check voltage on each of these wires when using the switch. Or just measure voltage at the motor when you are rolling up/down the window and tell us if you have voltage there.
I think you said earlier that you did have voltage at the motor. If you do then the motor is the issue. Let's start here and then move on. We basically just need to start somewhere and fix one of them and hope they are all related and they all get fixed. Trying to figure out the common component does not seem like it is going to pan out as there is nothing obvious.
Sep 10, 2020 at 6:53 PM
