Window regulator motor cable placement
1997 FORD CROWN VICTORIA
150,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
DANBO46
  • 12 POSTS
I took the window cables off the motor, one goes on the top of the reel and the other goes on the bottom. I need to know the cable that makes the window go up where is it placed on the motor top or bottom of the reel.
Dec 15, 2018 at 5:56 PM
Good evening,
Why did you remove the cables? They should never be touched as they should be spring loaded.
Did they come off?
Dec 15, 2018 at 6:45 PM
DANBO46
  • 12 POSTS
One cable came off.this is what I need to know on the spool they have two inserts one at the top for one cable and one at the bottom for the other cable. When the window goes up what cable goes on the top insert? And to make the window go down where do you place that cable?
Dec 15, 2018 at 7:11 PM
It is one cable that connects to each end. when the motor runs, it moves the whole cable which drives the regulator up or down.
there are not two separate cables, they is only one cable.
Dec 15, 2018 at 7:18 PM
DANBO46
  • 12 POSTS
On my Crown Victoria there is two cables one makes the window go up and one that makes the window go down. One is short the other is long. Does the short cable go on the top insert?
Dec 15, 2018 at 7:38 PM
yes.
Dec 15, 2018 at 7:40 PM
DANBO46
  • 12 POSTS
Thank you so much. I have been pulling my hair out with this. It got dark on me when I disconnected them.
Dec 15, 2018 at 7:50 PM
You are welcome.
Always glad to help.
Dec 15, 2018 at 7:52 PM
DANBO46
  • 12 POSTS
Have you ever been to New Orleans? That is where I live. If you ever get a chance, grab up the family and come see the Mardi Gras.
Dec 15, 2018 at 7:57 PM
I teach down there two times a year. I travel all over the country on site and have been there.
Good town, good times.
Dec 15, 2018 at 8:01 PM
DANBO46
  • 12 POSTS
I have a 2001 Nissan Xterra do you know a better way to replace the knock sensor which is located under the intake manifold without removing the intake?
Dec 15, 2018 at 8:06 PM
Since this is another vehicle, please go to the beginning and start a new question. that is site rules.
www.2carpors.com/questions
Dec 15, 2018 at 8:13 PM
