The passenger window in my car was not working, so I took off the door panel and removed the window regulator. Using a test light, with the ignition on, I verified power to the switch. I verified power going out of the switch for the two wires going to the motor. These were purple and brown.
Next, I verified power at the plug for the motor. If I put the test light on one terminal and pull the switch, I get a light. If I push it, nothing. Changing to the other terminal shows a light on push, nothing on pull. That seems like what I would expect.
Next, I plug in a new motor by itself. If I move the switch one way, the motor engages. Great. If I move the switch the other way, nothing.
Just for giggles, I tried the old motor. Same thing.
Am I missing something here? The plug for the motor just has two wires. Is one supposed to complete the circuit while the other shows power? Or is there something I should expect differently?
Apr 28, 2018 at 7:34 PM
