Window motor or actuator replacement
2015 TOYOTA HIGHLANDER
35,000 MILES • 6 CYL • 4WD • AUTOMATIC
PLAINS2HILLS
My drivers side window quit working about a week ago. I can still operate all other windows from the drivers switches, just not the drivers side window. When I push the drivers window button I can hear a click noise where I believe the window motor is, but that is all. I’m guessing it’s not the switch since the other windows work from the position. What are the best steps for isolating whether it is a failed actuator or motor? Also, is there a resource showing how to remove/replace one of these? Thanks in advance!
May 12, 2019 at 5:28 PM
Welcome to 2CarPros.
It sounds like the motor if you only hear a click.
Here are the directions for removal of the motor. The attached pictures correlate with the directions.
___________________________
REMOVAL
CAUTION / NOTICE / HINT
HINT
* Use the same procedure for the RH side and LH side.
* The following procedure is for the LH side.
PROCEDURE
1. PRECAUTION
NOTICE:
After turning the ignition switch off, waiting time may be required before disconnecting the cable from the negative (-) battery terminal. Therefore, make sure to read the disconnecting the cable from the negative (-) battery terminal notices before proceeding with work.
See: Vehicle > Technician Safety Information > Repair Instruction - Precaution
2. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
NOTICE:
When disconnecting the cable, some systems need to be initialized after the cable is reconnected.
3. REMOVE FRONT DOOR LOWER FRAME BRACKET GARNISH
See: Front Door > Overhaul > Disassembly
4. REMOVE FRONT DOOR INSIDE HANDLE BEZEL PLUG
5. REMOVE POWER WINDOW REGULATOR MASTER SWITCH ASSEMBLY WITH FRONT DOOR UPPER ARMREST BASE PANEL (for Driver Side)
6. REMOVE POWER WINDOW REGULATOR SWITCH ASSEMBLY WITH FRONT DOOR UPPER ARMREST BASE PANEL (for Front Passenger Side)
7. REMOVE COURTESY LIGHT ASSEMBLY
See: Courtesy Lamp > Removal and Replacement > Removal
8. REMOVE FRONT DOOR TRIM BOARD SUB-ASSEMBLY
9. REMOVE FRONT DOOR SERVICE HOLE COVER
10. REMOVE FRONT DOOR GLASS SUB-ASSEMBLY
11. REMOVE FRONT DOOR WINDOW REGULATOR ASSEMBLY
12. REMOVE POWER WINDOW REGULATOR MOTOR ASSEMBLY
(a)Using a T25 "TORX" socket wrench, remove the 3 screws and power window regulator motor assembly.
pic 1
______________________________________
Install:
HINT
PROCEDURE
1. INSTALL POWER WINDOW REGULATOR MOTOR ASSEMBLY
NOTICE:
The regulator arm must be below the intermediate position when installing the power window regulator motor assembly.
(a)Using a T25 "TORX" socket wrench, install the power window regulator motor assembly with the 3 screws.
Torque : 5.4 Nm (55 kgf-cm, 48 in-lbf)
HINT
When replacing the power window regulator motor assembly, a new power window regulator motor assembly uses self-tapping screws to thread new installation holes when the self-tapping screws are installed.
2. INSTALL FRONT DOOR WINDOW REGULATOR ASSEMBLY
See: Front Door > Overhaul > Reassembly
3. INSTALL FRONT DOOR GLASS SUB-ASSEMBLY
4. INSTALL FRONT DOOR SERVICE HOLE COVER
5. INSTALL FRONT DOOR TRIM BOARD SUB-ASSEMBLY
6. INSTALL COURTESY LIGHT ASSEMBLY
See: Courtesy Lamp > Removal and Replacement > Installation
7. INSTALL POWER WINDOW REGULATOR MASTER SWITCH ASSEMBLY WITH FRONT DOOR UPPER ARMREST BASE PANEL (for Driver Side)
8. INSTALL POWER WINDOW REGULATOR SWITCH ASSEMBLY WITH FRONT DOOR UPPER ARMREST BASE PANEL (for Front Passenger Side)
9. INSTALL FRONT DOOR INSIDE HANDLE BEZEL PLUG
10. INSTALL FRONT DOOR LOWER FRAME BRACKET GARNISH
11. CONNECT CABLE TO NEGATIVE BATTERY TERMINAL
NOTICE:
12. INITIALIZE POWER WINDOW CONTROL SYSTEM
* for Models with Jam Protection Function on 4 Windows:
See: Windows > Programming and Relearning > Initialization
* for Models with Jam Protection Function on Front Door Windows:
13. INSPECT POWER WINDOW OPERATION
See: Windows > Initial Inspection and Diagnostic Overview > Operation Check
May 12, 2019 at 9:22 PM
PLAINS2HILLS
Joe, thank you! This is incredibly helpful. You mentioned photos for each step. I'm seeing the one photo showing the motor and actuator assembly. Maybe I'm looking in the wrong area on here? Thanks again for your help.
May 13, 2019 at 5:50 AM
Welcome back:
No, you are correct. The motor and regulator are bolted together. The regulator is what moves the window via power from the motor.
Does that make sense? LOL It is always so much easier when the person is with me.
May 13, 2019 at 5:23 PM
PLAINS2HILLS
Thanks again Joe. Sorry for the misunderstanding. What i meant was, your initial message said that there were photos corresponding to the directions, but I was only seeing one image attached. Are there more photos? thanks again for all of the help.
May 16, 2019 at 9:04 AM
Welcome back:
No problem at all. Honestly, I was most likely typing fast and added an s. Is there anything other you need pictures for? If so, I can try to find what you need.
May 16, 2019 at 6:13 PM
