How to repair the window handle cap that keeps coming off?
1991 PLYMOUTH ACCLAIM
132,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
TOMSCP
  • 64 POSTS
When I roll the window up or down the cap on the window handle keeps coming off and I have to keep snapping it back on. I lubricated the window track but did not help. Please see pictures one with the cap on and the other with the cap off.
Oops, all of a sudden I cannot download pictures here it keeps stating "file type not accepted". How do i fix this?
Aug 28, 2021 at 5:56 AM
Save the file as a jpeg. That should take care of the issue.
I'll watch for your reply.
Aug 28, 2021 at 10:39 PM
TOMSCP
  • 64 POSTS
Joe, I saved both as jpeg but I still get the same error?
Aug 29, 2021 at 5:14 AM
TOMSCP
  • 64 POSTS
I just uploaded them to my yahoo mail with no problem, what could I have done wrong?
Aug 29, 2021 at 5:26 AM
TOMSCP
  • 64 POSTS
Could there be something wrong with your ADD IMAGE process, even the pictures i already uploaded here will not up load now?
Aug 29, 2021 at 8:50 AM
TOMSCP
  • 64 POSTS
Okay, I think I know what I did wrong. here are the two pictures one with the handle cap on and one with it off, it keeps coming off when I roll the window up or down. need to know how I can tighten it. Thanks
Aug 29, 2021 at 10:34 AM
That is a plastic handle/knob. Over time, they wear out and are not repairable. In this case, there is nothing you can do to tighten it. The handle needs replaced. Dorman (an aftermarket parts company) makes one. The Dorman part number is 76879 for your vehicle.
I looked quickly and most parts stores can get one for you for around 10 dollars. See pic below. Also, I am in no way affiliated with Auto Zone or Dorman. AZ was the first site that came up and I know and have used Dorman parts for years.
Let me know if this helps.
Aug 29, 2021 at 7:29 PM
TOMSCP
  • 64 POSTS
Instead of wasting $10.00 on a new handle what I will try is too.
switch the whole back door handle with the front door handle, that should hold me over. Ha Ha just when you thought I could not be any cheaper, I fooled ya, !!!LOL!!! Thanks Joe will let you know if it works out.
Aug 30, 2021 at 5:05 AM
I am all about saving money. LOL. They should be the same. If they are different and no one uses the passenger side front, use that one. Or, if there is a u-pull it salvage yard nearby, I can't imagine they would charge more than a couple of dollars.
Let me know how things work out for you and as always, let me know if you have other questions.
Aug 30, 2021 at 5:32 PM
TOMSCP
  • 64 POSTS
Joe, I switched the handles and will be using them for a few days, will let you know if its any better!
We use to have junk yards in phila. but don't know of any left. Will investigate and see if there is any, I could use a good place to get hard to find parts. Later, Tom
Sep 2, 2021 at 4:18 AM
Sounds like a plan. I'm on the opposite side of the state from you, near Pittsburgh. We still have tons of them. If you can't find one, let me know and I'll run to a u-pull it and get one, if available, for you.
Sep 2, 2021 at 7:11 PM
TOMSCP
  • 64 POSTS
Thanks Joe, will do!!!
Sep 3, 2021 at 4:46 AM
