Window actuator replacement
2002 FORD GHIA
180,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
ZERAGAMBETTA
Hi, I have a new window actuator to replace, I have got through most of it but I am having trouble removing the window from the old actuator. The white clips mounted on the window will not unclip/pry-off/slide off from the black clips on the old actuator.
Please help. :)
May 10, 2018 at 9:04 PM
Here is a guide to help you see what you are in for when doing the job:
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Please send pictures or videos of what problem you are having. Here is how the book says to do the job. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
May 13, 2018 at 1:55 PM
