If the indicator is working, that tells me the range sensor is working. Either we lost the transmission or for some reason pressure has dropped. The best thing to do would be to have the computer scanned with a scanner which can read transmission codes. Otherwise, we need to check line pressure.
I don't know how comfortable you are with checking, but here are the directions for checking line pressure on the transmission. This is where I would start if I didn't have a scanner.
_____________________________________________
1999 Lexus Truck RX 300 AWD V6-3.0L (1MZ-FE)
Hydraulic Test
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Testing and Inspection Component Tests and General Diagnostics Hydraulic Test
HYDRAULIC TEST
HYDRAULIC TEST
Measure the line pressure.
NOTE:
- Do the test at normal operation fluid temperature 50 - 80 °C (122 - 176 °F)
- The line pressure test should always be carried out in pairs. One technician should observe the conditions of wheels or wheel stoppers outside the vehicle while the other is doing the test.
- Be careful to prevent SST's hose from interfering with the exhaust pipe.
1. Warm up the ATF.
2. Remove the test plug on the transaxle case front left side and connect SST.
SST 09992-00095 (09992-00231, 09992-0271)
3. Fully apply the parking brake and chock the 4 wheels.
4. Connect an OBD II scan tool or LEXUS hand-held tester to DLC3.
5. Start the engine and check idling speed.
6. keep your left foot pressed firmly on the brake pedal and shift into D position.
7. Measure the line pressure when the engine is idling.
8. Depress the accelerator pedal all the way down. Quickly read the highest line pressure when engine speed reaches stall speed.
9. In the same manner, do the test in R position.
pic 1
Specified line pressure:
If the measured pressure is not up to specified value, recheck the throttle cable adjustment and retest.
pic 2
Evaluation
Let me know. Also, if you have never changed the transmission fluid, you may consider removing the pan to confirm the filter isn't plugged.
Dec 31, 2019 at 8:48 PM
