Will this engine fit into my car listed above? It is the SE? model.
Take a look at https://goo.gl/GsxUqa
Sep 21, 2017 at 12:39 AM
STEVE W.
CERTIFIED EXPERT
If your G6 has the 3.5L V6 you indicated the 2.4L I4 will not work. You need another 3.5.
Trans-axle, wiring, computer, exhaust, cooling, dash and suspension are all different between those engines.
Plus you really want to avoid an engine from a vehicle involved in a front impact that hard unless you can inspect it before you buy it. Because of the way things fit and how they mount an impact like that can break parts that you need.
