Will these line up and work properly together
1984 CHRYSLER 200
200,000 MILES • AUTOMATIC
SHELBIE KADIVA
  • 14 POSTS
Pickup
Pk4028822
59883455
Transmission
Tk405829
6270
3799
May 1, 2020 at 6:34 PM
Can you give a little more detail on what you are looking for? Are you trying to find out if the transmission that you mentioned will line up with a truck or the 1984 Chrysler? If so, can you provide more info about the vehicle?
Just not sure what exactly you are looking for so we can give accurate info. Thanks
May 1, 2020 at 8:02 PM
SHELBIE KADIVA
  • 14 POSTS
Yes, the pickup is a 1984 automatic rear wheel drive.
3/4 ton 360 engine
V8
90,000 miles are on it.
May 1, 2020 at 8:54 PM
Okay. That is helpful but can you give me a little more detail about what the transmission is? Those numbers I suspect are the supplier numbers and they don't actually pull up what transmission it is. Thanks
May 2, 2020 at 5:17 PM
SHELBIE KADIVA
  • 14 POSTS
I actually have the wrong start number. it should I'd of been for the truck
PK4028822 5988 3455
Transmission number PK405829 6270 3799.
May 2, 2020 at 5:30 PM
Can you get a picture of where you are getting these numbers from? They are just not part numbers so they don't pull up any results so I suspect they are supplier numbers that don't get published anywhere other then in the internal systems of the supplier.
May 3, 2020 at 9:45 AM
