I had a 1860 code for the solenoid. I replaced the wiring harness and TCC solenoid. The car will only go in reverse an neutral. I have enough fluid. The other solenoids worked fine before, as far as I know. This repair cleared the check engine light and it's not throwing another light for the other solenoids. I do not know what else you check. The only issue before repair was that code. Could I have mis-aligned that piston or gear when putting the valve body back on?
Dec 1, 2019 at 12:53 PM
