Gentlemen. Your reply sounds like you really want to help. So, let me begin. This Saturn L300 with 169,000 miles. The past few months. When attempting to start. would not fire right up, instead would slowly run the starter, and after a few seconds maybe up to 10 seconds would start and run normal. Then would start normally for weeks. I had gotten use to this, thinking it had something to do with a bad ignition switch and if it no longer started. I would replace the switch. It has codes. Bad heater on the O2 sensor bank 1. Warm up catalytic thermostat temperature below normal, Coolant thermostat temp below normal, And Transmision control system ML request. The trans ever so often shows the wrench symbol and goes into limp mode but goes away on restart. These Codes pop up, but it ran well otherwise. Result I could clear codes and get it thru inspection then drive around with the check engine light on. This Non running condition is new. The current codes it is throwing out are. PO123, Throttle position senser Hi Voltage. Po222, Throttle position sensor B circuit low, and Still getting Transmision Control System MIL Request. The other codes have vanished because the engine will not start. I watched the Video. on Throttle position sensor cleaning and although I had brushed cleaned it in place, I did not remove it as shown to clean it. This I will do right now and before sending this report on what happens. As to Fuel pump, the highest pressure I am seeing is 40 PSI. My Snap On friend told me last night that this is too low, The Saturn Forum says 40 PSI is good without the engine running. So, I'm still not sure if I have a fuel pump issue. Again, I have the Tank dropped, anticipating a bad fuel pump and will leave it that way until I find the problem. See Throttle activator plug. Two questions. #1 can I put 12 volts to one pin and modulate the Valve to see if the motor works. #2 if I put a 38-dowel in and open the shutter 3/8" would the pump stay running, and the car run at 2000 RPM's? I broke the paper gasket, new one to arrive tomorrow. Shown photos of clean part, and plug.
Aug 17, 2022 at 12:23 PM
