will not start when temp is cold
1991 MAZDA B2600
230,591 MILES • 2.6L • 4 CYL • 4WD • AUTOMATIC
WINFIELDJBW1
truck wont start without spraying it when temp is cold. starts after a couple tries in warm weather. bought vehicle not running and have rebuilt engine, replaced fuel pump, fuel filter, and all injectors. vehicle starts right up after spraying with carb cleaner. will start rest of day if not left sitting too long. previous owner had this same problem. have seen this same problem described on several forums, but no solution. and help would be appreciated. thanks
Dec 4, 2015 at 12:22 PM
HMAC300
  • 48,601 POSTS
check fuel pressure at idle with a gauge should be 31-38 w/ vacuum hose to regulator and 38-46 w/o. if no signal from dist injectors will not work.
Dec 4, 2015 at 3:20 PM
