Will not start after replacing the fuel pump
1995 CHEVROLET CAMARO
200,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MWL195ZLT1
  • 14 POSTS
Car listed above is a Z28 LT1 with rebuilt 4L60e a bunch of new parts, but these seem pertinent: new heads, injectors, plugs and wires, distributor, Opti spark, timing chain, ICM, coil, battery, starter, fuel pump-255LPH High Performance In-tank Fuel Pump from UltimateComponents. Anyway, I drove it into the garage to change the fuel pump which only had max 35PSI at key on. Now it won't start. double checked all the wiring at the pump. It just turns over and over and over. Put a battery booster on it to ensure good spark. No spark to plugs. Fuel rail at key is now 50PSI. At a loss to proceed. Thanks for listening.
Dec 20, 2021 at 7:07 PM
If there is no spark, have you confirmed there is power to the coil? At the distributor, the connector should have a red wire. With the key in the run or start position, that wire should have power.
I'm struggling to connect the fuel pump replacement causing this, but we'll figure it out.
Let me know about the power to the coil. Also, if you have a live data scanner, see if there is an RPM signal when cranking.
Let me know what you find.
Dec 20, 2021 at 9:03 PM
MWL195ZLT1
  • 14 POSTS
There is power at the coil with key on. I do not have a scanner. There is power at the injectors. I am going to check all the grounds to neg terminal next, maybe that will turn up something. I get a fuel filter today and will install it. I haven't tested for any vacuum as I can't imagine it would prevent spark. Thanks again
Dec 21, 2021 at 7:01 AM
MWL195ZLT1
  • 14 POSTS
Oh, there is no security light lit on dash.
Dec 21, 2021 at 7:02 AM
I attached a couple of pics below that you may find helpful. One other thought. Did you check the 10 amp fuse in the under-hood fuse box (fuse 11) that is specific to the ignition? Also, have you checked the ignition control module?
See pics below. Also, pic 3 shows the fuse I'm referring to. When checking, make sure there is power both to the fuse and from it.
Dec 21, 2021 at 1:53 PM
MWL195ZLT1
  • 14 POSTS
Fuses are all good and reseated. The ICM is brand new but put the old one back in just in case, but no change, just a continuing turnover. There is spark going to the coil but none out! Testing negative post and one on the positive post of the coil results in 1.5ohms. Put the old coil back just to try. Checking both from side terminal and one in the center high tension terminal gives just above 8k ohms. One change has occurred when the key is turned on - security lights up and then goes out and the check engine light stays on. I borrowed a reader. I plugged it in and turned the key on. The reader goes through a self-check, checks the VIN and starts counting in percentages, quitting at 50% and displaying error message that it cannot continue - no other message. I am truly stumped. I got the PCM (flashed to my VIN) from FlashMasters off eBay. When I got it, plugged it in and the car fired right up, took it for a 10-15 minute ride and noticed the car did not get up to power and idled rough and would shut off. Pulled into the garage waiting on the new fuel pump. After the fuel pump was installed is when it wouldn't start. Stumped!
Dec 21, 2021 at 2:57 PM
Just for the heck of it, take the distributor cap off and have someone crank the engine. See if the rotor moves. Also, resistance seems high on the coil. If I recall, 1 ohm should be max.
Also, take a look at the three pics below. Each one is a different diagnostic flow chart. Each of these three codes can cause a no-start condition due to spark.
You are certain the fuel pump is running, correct?
Let me know if that helps in any way.
See pics below.
Dec 21, 2021 at 4:20 PM
MWL195ZLT1
  • 14 POSTS
Distributor moves okay with the key and pressure at rail is 50PSI and holds. I will run down the DTCs in the morning. Thanks
Dec 21, 2021 at 4:49 PM
You are very welcome. Hang in there. We'll get it going.
Dec 21, 2021 at 5:13 PM
MWL195ZLT1
  • 14 POSTS
Tried a different reader and it quit after 50%, so I am returning the PCM and having them send another. They will diagnose the return and let me know what went wrong, etc. Will post more later. Oh we installed the steering column with the correct nr 9 resistor key, and it made no difference. Another pointer that its the PCM VATS failure.
Dec 22, 2021 at 6:33 PM
It sounds like you are on the right track. Let me know what happens. I'm really interested in knowing.
Take care and I hope you have a great Christmas.
Dec 22, 2021 at 9:23 PM
MWL195ZLT1
  • 14 POSTS
The flashmaster tech says my friends Hypertech device is not a reader but a programmer and must be defective as the PCM I returned no longer responds. Waiting on the new PCM. Will update later.
Dec 24, 2021 at 10:15 AM
I'm not really familiar with Hypertech, but I do know they make programmers.
Regardless, let me know if that takes care of it. I'm interested in knowing.
Dec 24, 2021 at 4:03 PM
MWL195ZLT1
  • 14 POSTS
Will do.
Dec 25, 2021 at 10:38 AM
I noticed it has been a couple of days since I heard from you. Have you been able to make any progress or tied up due to the holiday? LOL
Just checking in to see if you need anything.
Dec 27, 2021 at 2:40 PM
MWL195ZLT1
  • 14 POSTS
I got the new PCM today. Connected it and turned the key on only to get a solid security light (not blinking). Went ahead and tried to turn it over. No fire. Disconnected the battery. waited five minutes and tried again. This time it fired right up, started it down the driveway to ease it around for 20 minutes as Chevrolet suggests for the PCM to set. Halfway down the driveway I had to give it a little gas to avoid bogging down in the sand - it quit as soon as I actuated the gas pedal and would not refire. Towed it home, washed my hands and sat stupefied and sent you this... The resistor on the original key was 2.8ohms. The key set was lost by the last owner who had a 2.8 resistor inline from the ignition to the PCM, which we were previous to the gas pump exchange firing a-okay. So, with the new PCM which was flashed to the VIN of the vehicle, could the imbedded resistor setting be different than before making the 2.8 inline resistor incorrect? Too many things for my pea brain...
Dec 27, 2021 at 4:58 PM
They can be confusing. Also, anytime people modify things, it usually leads to problems.
So, I need you to try something. Turn the key to the run position so the security light turns on. Allow it to sit for approximately 10 minutes. Does the light turn off and will the vehicle then start?
Let me know. Also, you were worried about getting stuck in the sand. I wish I lived there. LOL
Dec 27, 2021 at 7:34 PM
MWL195ZLT1
  • 14 POSTS
Oh, the sunshine and 77 degrees will make for an excellent round today. Got a list of the keys numbered with their ohms. Will go up the chart an try all settings. I have already got through to 3.0. Will post later.
Dec 29, 2021 at 8:27 AM
I noticed it has been a couple of days since I heard from you. Have you been able to make any progress? I'm interested in knowing.
I hope you have a great New Year!!!
Dec 31, 2021 at 9:45 PM
MWL195ZLT1
  • 14 POSTS
Weekend off to the beach. Just got back. Will update tomorrow night about getting a VATS and PCM from a 95 Z28 that got sandwiched broadside, but still starts every time. My friend is going to pull everything from the wreck while I pull it from my car.
Jan 1, 2022 at 4:14 PM
Sounds like a plan. I hope you had a good time at the beach.
Jan 1, 2022 at 10:34 PM
MWL195ZLT1
  • 14 POSTS
Didn't work. Pulled the wiring from the fuel system and laid down new wiring. Examined old wiring and did not find a scrape, break or rust in it, but it is absolutely unbelievable - runs great. Dyno'd at 366hp. Guess someone worked on the bottom end. Going to put headers and a nit kit to get near or just over 400. Be fine for daily driver. Thanks for the sounding board.
Jan 6, 2022 at 3:02 PM
Sounds great. Was it the wiring to the pump that was the problem? Interestingly, the actual wire covered with the rubber insulator can break inside and the insulation looks perfect. I wonder if that is what happened?
Jan 6, 2022 at 4:53 PM
MWL195ZLT1
  • 14 POSTS
Curious too, so I stripped back the insulator wrap from pump head going forward and didn't find any breaks. There were a couple of flat spots where wire retainers were tight around the wire. I remain baffled but happy that it is running.
Jan 7, 2022 at 9:11 AM
I'm glad you got it running as well. It sounds like it's running really well, too.
As far as the wire, I have had similar issues where the internal wire has broken but the insulation wasn't damaged, so it was very hard to find. The only indicator was there was no continuity from end to end on the wire until it was moved around. It can be very frustrating.
Regardless, I'm glad it's fixed. Take care of yourself and feel free to come back anytime in the future. You're always welcome here.
Jan 7, 2022 at 6:11 PM
MWL195ZLT1
  • 14 POSTS
Just as a courtesy (since the car started the same systems all over again two days later) I want you to know that the basic problem was in testing methods of the ignition control module and the coil. Even though we had power on the 12v line, and the grounds were good we failed to establish what ohms readings we were getting met the thresholds necessary to sustain constant power flow. The ohms reading on the original coil read 4.2 and on the new coil it read 4.28. Looking at specs in the service manual revealed that this reading was within tolerance. On a hunch (and connecting with a local speed shop who agreed) I went I got a coil for a 95 vette and tested it with a reading of 10.1 ohms. Install the vette coil and the car started immediately. Apparently the 95 Z28 and the 95 vette have the same power specs. Moral - if you have an engine that is the same engine used in a vette, use vette components your Z28.
Jan 21, 2022 at 12:42 PM
Thanks for that update. It is interesting that the specifications indicated you were good but in reality, it wasn't. Regardless, thank you for the update. I'm sure it will help others.
Take care of yourself,
Jan 21, 2022 at 5:51 PM
