will not start
2000 DAEWOO LANOS
200,000 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
BWREDFORD
No spark and no fuel pressure, cranks okay.
May 11, 2019 at 3:14 PM
Welcome to 2CarPros.
First, here is a link that discusses the most common reasons for a crank no start condition. Take a look through it.
The first things I need you to check will be simple. I need the fuel pump fuse and the ignition fuse checked. The fuel pump fuse (Ef16) is under the hood in the power distribution box. See pictures 1 and 2. Confirm it is good.
https://www.2carpros.com/articles/how-a-car-fuse-works
Next, I need you to check ignition coil fuse f15 in the interior fuse box. See pics 3, 4, and 5.
Here are a few links you may find helpful when testing the fuses and for power:
Let me know the results.
May 11, 2019 at 8:52 PM
