will not start
2018 CHEVROLET EQUINOX
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
HAZEL HOWARD
was driving my vehicle listed above when it sputtered like it had bad gas then lost power. error message said "reduced engine power".. went to turn around to go home that's when I noticed could not push in brake pedal very hard error message said "service park assist". finally got it home turned it off and now will not crank back up. brake fluid was low but I take it to a Chevrolet dealership for routine maintenance just took it in January 6. had it for 13 months no issues. what happened? why won't it start?
Mar 12, 2021 at 9:38 PM
Good morning,
The first thing I would do is check the fuel pressure to be sure there is sufficient fuel at the injectors.
https://www.2carpros.com/articles/engine-has-low-power-output
I attached the flow chart for the fuel system below.
Mar 13, 2021 at 6:27 AM
HAZEL HOWARD
I will definitely try it. fingers crossed lol.. I thank you for your time. will let you know if it works thanks again.
Mar 13, 2021 at 6:39 PM
You are welcome.
Always glad to help.
Mar 14, 2021 at 12:21 AM
CODY HUGHES2
Hey Roy, I have a question.
May 28, 2021 at 3:54 PM
Go ahead.
May 28, 2021 at 3:58 PM
