The problem is the truck will not start and fuel is not getting to the four injectors on the passenger side.
Here is a list of parts I have changed:
Fuel lift pump
Fuel shutoff
Fuel filter
Air filter
Ignition switch
Key tumbler
Two injectors
All glow plugs
Glow plug solenoid
PMD and heat sink
Turbocharger
Two new batteries (800cca)
Battery cables
Battery posts,connections,etc.
New starter
Cleaned all ground connections
Optical sensor
The starter is not spinning as fast as it should.
I am getting fuel to the lift pump, fuel filter housing,the injection pump,the T-valve drain,and to the four injectors on the driver side.
I do not know what else to do, and I am not familiar with reading a meter.
The truck was running one day and would not start the next. I have been working on this for a month!
Your help would be appreciated.
Thank you so much!
Fuel lift pump
Fuel shutoff
Fuel filter
Air filter
Ignition switch
Key tumbler
Two injectors
All glow plugs
Glow plug solenoid
PMD and heat sink
Turbocharger
Battery cables
New starter
Optical sensor
Thank you so much!
Jul 26, 2018 at 7:40 PM
