Hello again, if the wire to the starter is getting hot I would do a voltage drop check, to do this you will need a volt ohm meter. Set the meter to the lowest DC voltage setting. Keep in mind that you can use these voltage drop tests on any electrical components like the relay you keep mentioning by checking the voltage drop when unplugging the relay with the ignition switch on to energize the relay, and it might be advisable to pull that relay, charge the battery as this could be causing all your issues but we will start with the starter. First simply hook the the red to the battery positive post and the black to the negative post, you should have approximately 13 volts, next using a jumper wire or remote start button energize the "S" post on the solenoid and watch how much the voltage drops when the starter turns, it shouldn't drop below around 9 volts. If it drops more than that then the battery is week and needs to be replaced provided you started with around 13 volts, if it is below 12.5 volts charge the battery and retest the drop. The next drop you need to check will be the positive circuit to the starter, I would do this one in 2 ways, first connect one of the volt ohm leads to the positive post of the battery and the other to the positive on the starter, again jump the solenoid to activate the starter and see what the voltage drop is, it should be no more than .6 but depending on what engine you have it could be slightly higher for a big block. If the voltage drop is within range we can move on to a negative voltage drop however if it is not within range I would run the test again this time moving the lead from the battery to the starter side of the solenoid, if this corrects the problem run the test again going from the battery to the input side of the solenoid, if the problem resurfaces the cable going to the solenoid is bad or has a bad connection, if it doesn't the solenoid is bad. The nest circuit to test is the ground circuit, connect one of the leads to the negative post and connect the other to the starter housing, again jump the solenoid to activate the starter and watch the voltage reading, much more than .8 would be more than what is considered acceptable. Keep in mind the reason I say to jump the solenoid is so the engine doesn't start during testing, alternately you could take one of the wires off the coil and have someone turn the key for you , but either way I would also recommend clamping the hose that feeds the fuel pump to prevent flooding the engine. If you get an excessive voltage drop on any of these tests and you are sure that all of your wires/cables have a good connection then I would be concerned that the engine has an issue causing excessive load on the system, at this point I would pull the spark plugs and then put a breaker bar on the crank pulley bolt and see if the engine turns freely and consistently without dragging at any point. If you find it difficult to turn at any point then you have an engine problem. Please keep us up to date on your progress.
Nov 26, 2019 at 4:20 AM
