Transmission will not shift into overdrive or third gear
2005 GMC YUKON
280,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
MARK PARKER2
Will not shift into third or overdrive.1st and 2nd gears perfect. Instead of shifting to 3rd it seems to go into neutral.
Jan 19, 2022 at 12:08 PM
Good morning,
There is a good possibility it is either the valve body in the transmission or the clutches are burned out inside the transmission.
https://www.2carpros.com/articles/automatic-transmission-problems
I would start by dropping the pan and looking for debris in the pan's magnet. Check for any chunks as well. This will help me to narrow the area of failure.
Jan 20, 2022 at 6:22 AM
