The vehicle had not had any problem with shifting but suddenly would not move forward or reverse when put in those gears. The shift indicator shows it moving to each position correctly. Transmission fluid level good, no leaks. When first started it can be driven in forward, reverse, third or second and gears changed for a short time, few minutes. Eventually changing gears stops working and it does not move at all. If I turn off engine and wait only five or so minutes I can restart the car and back it out, change to forward and drive it around the house at normal speed and acceleration, but once I stop it will not move forward or reverse until I turn the engine off and restart it. I noticed that I can read the transmission dipstick okay immediately after starting the engine (top of xxx area, second hole), but when it is in "no go" mode the fluid shows it is way overfilled, the way it looks if the engine is not running when you check it. The fluid and filter have not been changed in years. Fluid is dark but not burnt smelling as far as I can tell. Can anyone tell me whether this is a fixable problem? I did a scan and the stored errors were engine knock, water temperature issue and a cam timing error. I work on my cars but not a transmission guy at all. Any help much appreciated.
Nov 17, 2018 at 8:28 PM
