Will not go into any gear
2004 SATURN VUE
150,000 MILES
JORDANJAQUEZ
I have an 04 Vue manual trans. It became really hard to shift in about 3 hors time while i was visiting a friend. On the way home i had to be kinda rough and i ended up breaking the shift cable bushing. long story short, i replaced the bushing as well as the shifter cables. Still it will not go in gear with engine on, with it off it will but when i start the engine the car kind of jerks like the clutch is not working properly. Any suggestions?
May 9, 2013 at 10:37 AM
This sounds like your clutch is failing and not allowing the the shifter to engage. Here is a guide that talks about this a little more:
https://www.2carpros.com/articles/clutch-symptoms
Also, here is a guide that covers how to replace a clutch and needed components:
https://www.2carpros.com/articles/how-to-replace-a-clutch
Lastly here is a video that shows how to do this on a front wheel drive vehicle like you have:
https://www.youtube.com/watch?v=6N6b5F2ChyE
Run through this material and we can go from there. Thanks
Dec 22, 2020 at 6:05 PM
