Changed motor mounts now engine will not crank?
1999 FORD FREESTYLE
10,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
TMLM1969
Changed motor mounts now it will not crank?
Sep 21, 2024 at 3:14 PM
Do you have the battery ground cable connected? Also, did you remove the starter when you did the mounts? If so, recheck the connections at the starter and clean the battery cable ends at the battery. Please go over this guide which should help you figure it out:
https://www.2carpros.com/articles/starter-not-working-repair
and this video as well:
https://youtu.be/6YRW8fyNudY?si=t-Q7AVPD4p5XNAhc
Please go over these guides and get back to us.
Sep 22, 2024 at 10:40 AM
