So I changed injector for cylinder 4 as it was faulty, this problem had my car In limp mode and PCM light on! The car would be rough on start up and then lights come on and go into limp mode! Since changing the injector the car runs perfectly and not rough idle on start up! However as I drive the car and go through the gears it’ll lose power and jump back into limp mode with the PCM light and now engine light. is this normal when the previous fault code hasn’t been cleared? Will clearing the fault codes sort this? Thanks! The car is a 1.4 tdci 2009 mk7.
Jun 26, 2020 at 3:25 PM
