Why will the car engine not crank over?
2010 BMW X1
20,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
KUBSKI
I have a good alternator, good starter, good battery, no wrong codes or so. The battery doesn’t charge while driving. The car won’t start without helpstarter. I found those two red cables that are going to battery lately.
May 4, 2023 at 12:59 PM
The fact that it won't start without a helper battery tells me the battery is no good, the starter is weak, or the battery cable connections or cables are bad. I would start by cleaning the cables and make sure they are tight.
This guide can help:
Next here is a battery load test you can do while using the car as a tester:
Please go over these guides and report back.
May 5, 2023 at 9:23 AM
