I do not hear the fuel pump turn on when I turn the key to on
2007 TOYOTA CAMRY
255,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
JOE1953
  • 772 POSTS
when i turn the key to on i do not hear the fuel pump run or come on. when i crank the engine there is no spark from the coil why? what i need to check to fix the problem or what is causing no fire and the fuel pump not coming on?
Oct 19, 2016 at 6:30 PM
AL514
  • 5,465 POSTS
Hello, can you give me the sub model of the car, such as CE, LE, SE, XLE?
Oct 20, 2016 at 2:36 AM
AL514
  • 5,465 POSTS
Also, start checking every fuse in the panels under the hood and under the left hand side of the dashboard (drivers side).
Oct 20, 2016 at 2:43 AM
JOE1953
  • 772 POSTS
the sub model is LE. i check all the fuses under the hood i did not find any blown. i could not find the fuse box under the dash. can you send me pictures of the fuse box?
Oct 20, 2016 at 8:35 AM
AL514
  • 5,465 POSTS
it is located up under the dash, center of the driver's seat. here is a diagram.
Oct 20, 2016 at 8:51 AM
JOE1953
  • 772 POSTS
i do not see anything say fuse box in the diagram. will i be interfering with the air bag?
Oct 20, 2016 at 9:13 AM
HMAC300
  • 48,601 POSTS
try a security system reset that may be the problem.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Oct 20, 2016 at 9:42 AM
JOE1953
  • 772 POSTS
the problem started when the wires that connect to the number two coil was touching each other. what happen i pull the connector end of the coil and it broke and the wires got out of order (line) and i did not really know where each wire connect back to, so did connect the four little wires on to the coil and when i started the car it had a misfire on number two cylinder. so i begin to check the four little wires connect to the coil they was cross up so i look at number one coil wires to see how each one was connected and i went from there. so when i started the car it was running good so the wires came of the second time i believe the wires were touching each other when the engine was running. when i turned the car off and tried to start the car again it would not start. could that have causing the problem or blown a fuses? the wires that connect to the coil do they go back to the ECM?
Oct 20, 2016 at 10:26 AM
HMAC300
  • 48,601 POSTS
yes, they go back to ECM, but before you decide to replace the ECM have a mechanic check this with a diagram and fix the connectors as it may be just that and not the ECM.
Oct 20, 2016 at 12:32 PM
JOE1953
  • 772 POSTS
will the connectors cause the fuel pump not to run?
Oct 20, 2016 at 7:23 PM
AL514
  • 5,465 POSTS
yes, and if you have pulled wires out of the ignition module/coil pack or whatever. Theres no telling if you have shorted out the ECM with wires touching or connecting them to the wrong wires and sending voltage back on circuits it shouldn't be on. There could also be more blown fuses you have yet to find. And yes there is a fuse panel under the dash, its J/B (junction Box)/.
Oct 20, 2016 at 7:34 PM
JOE1953
  • 772 POSTS
i found a blown fuse under the dash 15A i think it had something to do with the ground i replace it but now the engine will start and run for a few second and stop the fuel pmp sound real weak can't hardly hear it do this car have a fuel pump relay? i don't hear it click.
Oct 21, 2016 at 6:56 PM
HMAC300
  • 48,601 POSTS
if the pump runs the relay is okay.
Oct 22, 2016 at 5:26 AM
JOE1953
  • 772 POSTS
why i cannot hear the fuel pump relay click when i turn the key to run how do i check the relay?
Oct 22, 2016 at 8:26 AM
HMAC300
  • 48,601 POSTS
see picture on how to test relay but because of what you have done I highly recommend you taking this to a mechanic to see if he can find the problem.
Oct 22, 2016 at 11:28 AM
