Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Contour
Interior
Instrument Cluster
Gauges
Engine Temperature
Not Working
Temperature gauge stop working
1997 FORD CONTOUR
77,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DENNIS OMALLEY
MEMBER
FOLLOW
temperature gauge no work. changed temperature sensor by thermostat. does not overheat. heater still works the same?
Dec 23, 2017 at 10:05 AM
CERTIFIED EXPERT
It sounds like you have a thermostat that is stuck open which will cause the heater and the temperature gauge not to work as well.
Here is a guide to help you see what you are in for when doing the job:
Here is how it will be on your car (below).
Image (Click to enlarge)
Dec 24, 2017 at 11:14 AM
DENNIS OMALLEY
MEMBER
thank you. i will work on this Tuesday, December 26. Christmas is here.
Dec 24, 2017 at 1:06 PM
CERTIFIED EXPERT
Sounds good. ;)
Dec 26, 2017 at 11:19 AM
