Do you actually have low coolant? If this is the only warning light and then the engine will shut off and not restart, it may be overheating or at least think it is overheating.
Does you temp gauge stay steady and not showing it overheating?
If so, we could just have an issue with the coolant level sensor if the coolant is not low. Sometimes these vehicles will see the coolant low and the PCM will shut the engine off so that it is not damaged. However, this normally only happens when the addition of it actually starting to overheat.
I would suggest with starting with checking your coolant level and if it is low, top it off. Also, scan for codes. If you do not have a code reader, just stop by a parts store and pick up some coolant if you don't have any and ask them to scan for codes. They should do this for free if it is a larger chain type parts store.
Let me know the coolant level and then if there are any codes and we can go from there. Thanks
Sep 3, 2019 at 8:31 PM
