When driving it was loses power, sputters and dies
2001 MERCURY MOUNTAINEER
133,000 MILES • 5.0L • V8
TAMMIEWILD
I changed the two coil packs, clean the mass air flow sensor, it has a new fuel pump. Here is what happens; when your driving it loses power, sputters and dies. so we change the coil packs. When we change then it was idling rough but drove, but then the other day the same thing happened again and it will start, but then dies right away.
Oct 3, 2016 at 8:21 AM
HMAC300
  • 48,601 POSTS
try resetting security system if no owners manual look online on how to do it for your truck. if it continues have a mechanic scan for codes as it may be a security module issue.
Oct 3, 2016 at 9:22 AM
TAMMIEWILD
would that make it not run right or idle right? Could it be computer?
Oct 3, 2016 at 9:40 AM
Hi TAMMIEWILD,
It could be many things causing this but it sounds like it might be the cat converter being plugged up.
Here are a couple of guide that can help you,
and
Please let us know what you find so it will help others.
Best, Ken
Oct 3, 2016 at 11:53 AM
HMAC300
  • 48,601 POSTS
not running right could be anything so you shold start by scanning for codes and checking fuel pressure with a gauge. but when it cuts out after starting immediately that is a sign that it is a security issue. here is an article to help.
Oct 3, 2016 at 12:24 PM
TAMMIEWILD
we had it running for fifteen minutes but when you give it gas it cuts out, but not immediately.
Oct 3, 2016 at 1:02 PM
SATURNTECH9
  • 30,869 POSTS
I would check fuel pressure also for codes in the codes in the computer. As well as the catalytic converter for being plugged.That will let it run good then loose power and even die if it is plugged enough.
Oct 3, 2016 at 1:10 PM
Here is a thought, try disconnecting the TPS and EGR sensor and try it. Let us know how it goes.
Oct 3, 2016 at 1:38 PM
