Engine stalls while driving
2004 DODGE INTREPID
141,564 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
MVANN74
  • 65 POSTS
Just replaced the engine last week. Runs and drives fine although sometimes while driving when i press the accelerator car stalls. I have to press accelerator almost to floor.
I have to repeat this several times then car runs normally. Please help?
Jul 27, 2020 at 8:40 AM
Just to clarify, the engine stalls only when you go to wide open throttle but doesn't do this any more after you do it a few times?
This sounds like a throttle sensor or even an air intake sensor. Here is a guide that will help with this issue in more general terms. However, let's start with this info and go from there.
https://www.2carpros.com/articles/engine-stalls
Jul 27, 2020 at 3:15 PM
MVANN74
  • 65 POSTS
I believe i wasn't clear in my question. In order for the stall to pass I have to go to full throttle a few times. Then car will run fine after that. I put scan tool on and have these codes: p0175, p0172, p0132 and p0152. Which I think may have something to do with replacing o2 sensors?
Jul 27, 2020 at 4:16 PM
P0132 - o2 sensor circuit 1/1 voltage high
P0152 - o2 sensor circuit 2/1 voltage high
P0172 - Fuel System 1/1 rich
P0175 - Fuel System 2/1 rich
These codes are basically saying the same thing. They are both showing that the fuel system is rich. So we need to run through the testing that I attached to figure out what is causing it.
Let me know if you have questions and we can go from there. Thanks
Jul 28, 2020 at 5:11 PM
MVANN74
  • 65 POSTS
Thank you for your reply. I opened the hood yesterday and the left o2 sensor looking from front of car the black wire broke loose from sensor.
Should i just replace all 4? And which side is upstream and which side is downstream?
Jul 28, 2020 at 7:40 PM
Can you get a picture of what happened? If the wire is loose then you need a connector or wiring harness and not the sensor. The upsteam is in front of or before the converter. The downstream is below or behind the converter.
Let's get a picture and go from there. Thanks
Jul 29, 2020 at 8:20 PM
MVANN74
  • 65 POSTS
I got rid if the old sensor and replaced it with one that came out of the bad engine. Here is the pic. It's the black wire that was frayed and broke off the top of the sensor.
Jul 30, 2020 at 9:24 AM
So you replaced the sensor and pigtail with one that was okay? Sorry, but I don't see where the wire is damaged. Maybe get a closer picture of the damaged area. However, this wire can be repaired as long as you have enough slack on both sides to solder them back together.
Jul 30, 2020 at 6:26 PM
MVANN74
  • 65 POSTS
Understood. About an hour ago i was driving the car and the check engine began to flash and the engine stalled. I was lucky to make it home. So i parked it until i can replace the remaining 3 o2 sensors and try to clear these codes.
Jul 30, 2020 at 7:44 PM
Okay. Just to be clear, you replaced the sensor and wire that was damaged? If so keep us posted on what you find. Thanks
Jul 31, 2020 at 5:43 PM
