Why brake, engine, and TPM light on after a had spare tire put in?
2011 HYUNDAI ACCENT
8,000 MILES
TBANKS505
I just got the tires changed the morning of when I got a flat in the evening. I had a spare that is a little smaller than the rest put in. When I turned the car again after I had replaced the spare the engine, brake, and TPM light were all on and a little bit into driving it the brakes felt very loose and I had to push it to the floor to brake. When I turned it on this morning the brakes felt okay again bit the lights were still showing.
Apr 1, 2016 at 4:32 PM
HMAC300
  • 48,601 POSTS
tpm light is on because of no sensor in spare. once regular tire is installed it may go out our you may have to reset system. if engine /brake light on have it scanned for codes. the flat may have damaged abs sensor wires.
Apr 2, 2016 at 6:53 AM
