Yes, it is mandatory that there must be a door sensor/signal wire going to the BCM which looks after the position of the door closed or opened.
However, there are 2 signal wires (marked green color and Brown color) going to the BCM i.e. pin 6 and pin 17 of the BCM input connector. It is obvious that these 2 pins will, at the same instant, sense for the status of the door position either closed or opened.
Now, my main question is that why there are 2 door signal input wires, what is the purpose of having 2 signal wires to the BCM? And, is not only one signal wire sufficient to identify the status of the door?
There are no issues with the central door locking system in my i20 2011.
Just curious to know why 2 wires rather than 1?
Jul 22, 2023 at 1:43 AM
