Whirring noise
2007 VOLKSWAGEN GOLF
144,453 MILES • 2.0L • TURBO • 2WD • MANUAL
SCOTT WEBB
Whilst driving a whirring noise happens, it slows when I slow and gets faster when I drive faster. Please does anyone have any ideas? Tia
May 28, 2018 at 2:03 PM
STEVE W.
  • 15,113 POSTS
Most common cause for a whirring/buzzing type sound would be a wheel hub bearing starting to fail. Those will usually also change if you make turns while they are making noise. They sort of sound like mad bees. A bad bearing can make noise for months or it could fail tomorrow no real way to tell.
Next would be odd tire wear patterns. For those the sound would change depending on what the road surface is. Concrete/pavement/will sound different and it will stop on a dirt road.
If possible could you record a clip of it and upload it to this site? Hearing a noise can be real helpful in identifying it.
May 29, 2018 at 2:10 PM
SCOTT WEBB
Many thanks, it is constant even with steering.
May 30, 2018 at 10:53 AM
STEVE W.
  • 15,113 POSTS
In that case it could still be a rear bearing but most will change with steering. Next would be engine related.
If you set in neutral with your foot off the clutch do you still hear it or is it gone?
How about holding the clutch in?
Now take it out for a drive. Get it up to the speed where it is loudest or you hear it good and push in the clutch and coast. Does the noise stay and slow down with the car or does it go away?
Being a manual those tests will help isolate if it is engine or transmission related. I would say to shut the engine off and coast but that can be an issue in some cars.
Have you driven it on different surfaces at all?
Did this noise just suddenly start or has it slowly gotten worse?
May 30, 2018 at 4:06 PM
