Red lighting bolt light
2006 CHRYSLER 300
70,500 MILES • 3.5L • 6 CYL • RWD • AUTOMATIC
JR ESTRADA
It all started when my battery light was on. I got home turned off the car and open the trunk and the negative cable was dirty took it off and cleaned it off with a wire brush hooked it back up and tried to turn on the car and the battery died completely. I charged it for a while got it to turn on and thirty seconds later it shuts off and drains out the battery. what is happening?
Aug 9, 2016 at 7:35 PM
Hey JR,
It sounds like you alternator has gone out,, here is a guide to help you test it. You will need to get a new battery first which is a good idea if it is over three years old.
If it does test bad here is an replacement.
https://www.amazon.com/gp/search/ref=as_li_qf_sp_sr_il_tl?ie=UTF8&tag=2carprcom-20&keywords=2006-CHRYSLER-300-alternator&index=aps&camp=1789&creative=9325&linkCode=xm2&linkId=c93d83ac5d90f53e8fe47db826ab0ed7
Please let me know what you will find.
Best, Ken
Aug 12, 2016 at 10:36 AM
JR ESTRADA
And i also got these codes p0121 p1120 p0562 p1113 googled them and it said something about the throttle body.
Aug 12, 2016 at 11:38 AM
Yes you will have rouge codes when the battery dies, clear the codes once it is running and see if they return.
Aug 12, 2016 at 11:41 AM
