Good evening,
White smoke is an indication of a coolant burning in a cylinder. this is usually a result of a failed head gasket leaking coolant into a cylinder.
You will need to have a shop check out the engine for a failed head gasket. they need to do a leak down test on each cylinder to see if a gasket has failed.
that would also explain the rough running and increased fuel usage.
Jan 2, 2019 at 5:36 PM
