White smoke when accelerating
2016 HYUNDAI H100
255,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
SOMS SOMBI
  • 4 POSTS
White smoke coming out when acceleration and a rattle sound in the engine. How do I fix the problem?
Nov 10, 2019 at 7:15 PM
Hi:
White smoke usually indicates coolant is entering the combustion chamber. That is usually the result of a bad head gasket. Do me a favor. Take a look through this link. It explains how to check for a bad head gasket. Let me know what you find
and
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
I will watch for your reply
Nov 10, 2019 at 10:46 PM
SOMS SOMBI
  • 4 POSTS
Thanks a lot.
My vehicle starts normal as usual, but when I step on the accelerator pedal the white smoke comes out. Please need help to resolve the problem.
Cheers
Nov 13, 2019 at 9:42 AM
Have you tried the head gasket issues listed in the aforementioned post? When you say white smoke, is it coming from the exhaust?
If it is determine the head gasket is bad after testing, the only thing you can do is replace the gasket.
I have to be honest, this vehicle isn't offered in the US, so I have little to no technical info. I'm trying to help determine if the head gasket could be the issue. Also, check the engine coolant level to see if it is low as well as the other checks in the link.
Let me know what you find.
Nov 13, 2019 at 6:18 PM
SOMS SOMBI
  • 4 POSTS
Thanks for your help.
Nov 13, 2019 at 7:34 PM
Happy to help. Let me know what you find or if you have other questions.
Nov 13, 2019 at 8:58 PM
SOMS SOMBI
  • 4 POSTS
I replaced the head gasket and the problem is fixed. thanks a lot.
Nov 17, 2019 at 10:18 PM
Glad to hear it is fixed.
Take care and let us know if you need help in the future.
Nov 18, 2019 at 5:16 PM
