WHITE SMOKE FROM ENGINE ONLY ON PETROL
2001 TOYOTA COROLLA
162,000 MILES • 4 CYL • AUTOMATIC
MIANJAN95
  • 4 POSTS
Hi my car is giving white smoke continuously not only on startup .this only happens if car is running on petrol on cng (compress natural gas) the car is fine and no smoke i even changed the engine oil to Havoline 20w50 but still the problem is not solved
Oct 2, 2014 at 3:36 AM
HMAC300
  • 48,601 POSTS
have the coolant system pressure checked for a head gasket leak.
Oct 2, 2014 at 5:37 AM
MIANJAN95
  • 4 POSTS
gasket is fine i have done the tests and there is no leak any other idea
Oct 2, 2014 at 6:01 AM
HMAC300
  • 48,601 POSTS
the only other thing that I cold think of is that the pcv system may not be working right and causing this.white smoke is usually an indication of water or coolant leakage.so check yoru pcv valve to see if it's working properly . Other than that I can't think of anything
Oct 2, 2014 at 6:32 AM
MIANJAN95
  • 4 POSTS
could this be the piston ring problem ? they are damaged or weak ?
Oct 2, 2014 at 6:35 AM
HMAC300
  • 48,601 POSTS
if it were a piston ring problem the it would do it all the time. YOu can test compression though and if there is a 20% variance between any cylinder than it may be of concern but I kind of doubt it. the thing is when you switch between petrol (gas) and CNG you are going from a liquid to a gas so it may be something in the fuel as well causing it.
Oct 2, 2014 at 7:32 AM
MIANJAN95
  • 4 POSTS
exactly thats what i am thinking but i still want to confirm it from you as you are an expert if the piston rings were some how weak it should produce this white smoke on both cng and petrol right ?
Oct 2, 2014 at 7:37 AM
HMAC300
  • 48,601 POSTS
yes and per your statements it's not. so check compression other than that without seeing this myself I have no further comments or suggestions.
Oct 2, 2014 at 9:29 AM
