White smoke coming from exhaust intermittently/ Low coolant and Oil.
2003 JEEP LIBERTY
181,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
HANSONSKYLER
  • 4 POSTS
I notice from time to time that I have white smoke coming from my exhaust. I also noticed that I lose oil and coolant faster than I should. My Jeep does not over heat, and it runs fine, but this is still alarming for me. There are no puddles or any leaks of any kind under it either. To me, this seems like a head gasket. Would a pressure test identify the issue?
Oct 7, 2014 at 1:17 PM
WRENCHTECH
  • 20,761 POSTS
You shouldn't be losing any coolant at all. The white smoke is likely steam from coolant being burned in the combustion chamber, likely due to a blown head gasket or cracked head.
Oct 7, 2014 at 1:40 PM
HANSONSKYLER
  • 4 POSTS
So, should I compression test each cylinder? And if I do that and everything comes back ok, you're saying its most likely a cracked head? Also, is it weird that it runs, and drives fine other than the smoke/steam coming from the exhaust?
Oct 7, 2014 at 1:47 PM
WRENCHTECH
  • 20,761 POSTS
There are a number of ways to look for a blown head gasket. The compression test may or may not show anything. Another way is to remove all the spark plugs and pressure test the cooling system ad keep it under pressure for about 30 minutes and then crank the engine with the plugs still out and see if any of the plug holes spit out any coolant. A cylinder leakdown test would be another test that could be run.
Oct 7, 2014 at 3:23 PM
