I disassembled the top half of the engine and found that the intake gasket was cracked.I proceeded to tear it down to the head gasket and replaced the head gasket, all the gaskets from the head gasket on up are replaced and i still get white smoke.I pulled out the spark plugs and found that cylinders 3 and 5 had coolant in them.What will cause this?The heads are good,so could it be a crack in the block?
Sep 17, 2019 at 2:42 PM
