white cloud of smoke from exhaust only upon start up?
2008 NISSAN TITAN
78,000 MILES
DENTMC27
So I just got an 08 titan about 3 days ago and it was idling at the dealership with below a 1/4 tank of gas in it and ran completely out of gas once gas was put back in truck the next day white cloud of smoke from exhaust. Thank you for any help u can provide.
Apr 18, 2013 at 12:18 PM
SQM
  • 6,383 POSTS
There are several reasons why you could get white smoke during startup.
One of the common causes for these vehicles is leaking intake manifold gasket.
It can also cause if there is a leak in the head gasket. The leak can be too small to have excessive amount of coolant for it to have white smoke all the time but as the vehicle sits overnight or a period of time it will have some coolant that crates the white some on start up.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
There is a test that you can be done to see if the head gasket is leaking. It uses a chemical to detect combustion gases in the coolant.
Here is a helpful video on the test:
https://youtu.be/5zpNjYmmiYY
Thank you.
Oct 19, 2021 at 10:09 PM
