White bubbles in radiator when pressing accelerator pedal
2008 SUZUKI MEHRAN
61,000 MILES • 0.8L • 3 CYL • 2WD • MANUAL
SAJID358
Recently, my car starting overheating on high speeds. Sometimes it does overheat in traffic jams as well but normally it overheats on high speeds like 80km/hr +.and starts cooling down while in traffic jam. This is extremely strange behavior.
So I performed a radiator flush to flush all the old coolant which was around 2 years old. After flushing, when I started to bleed the air out of system, I opened the radiator cap and started pressing accelerator pedal. Upon pressing the pedal, I noticed whitish milky type bubbles appearing on top water surface but then they disappear when I release the gas pedal. Again when I pressed the pedal, white bubbles appeared on water surface which goes away upon releasing the pedal.
Jul 30, 2019 at 12:07 AM
SCGRANTURISMO
  • 4,897 POSTS
Milky bubbles in the coolant is a sign that your vehicle's head gasket might be blown. There are a few other ways to get coolant and oil co mingling together, but nine times out of ten it will be a head gasket. As far as when press on the throttle, that might be dislodging some of the bubbles, but usually neither engine oil nor coolant circulate through a throttle body. Here are a few links for you to go to down below:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 30, 2019 at 12:49 AM
